跳转到主内容
Hover-1 Titan Charge Port Replacement
你所需要的
  1. Hover-1 Titan Charge Port Replacement, Bottom Left Panel: 步骤 1 中的图像 1,2 Hover-1 Titan Charge Port Replacement, Bottom Left Panel: 步骤 1 中的图像 2,2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Charge Port Replacement: 步骤 2 中的图像 1,2 Hover-1 Titan Charge Port Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Charge Port Replacement: 步骤 3 中的图像 1,3 Hover-1 Titan Charge Port Replacement: 步骤 3 中的图像 2,3 Hover-1 Titan Charge Port Replacement: 步骤 3 中的图像 3,3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Charge Port Replacement, Charge Port: 步骤 4 中的图像 1,3 Hover-1 Titan Charge Port Replacement, Charge Port: 步骤 4 中的图像 2,3 Hover-1 Titan Charge Port Replacement, Charge Port: 步骤 4 中的图像 3,3
    • Unplug the red and black charge port wire from the motherboard by squeezing the connector located at the top right of the motherboard and pulling the connector away from the board.
  5. Hover-1 Titan Charge Port Replacement: 步骤 5 中的图像 1,3 Hover-1 Titan Charge Port Replacement: 步骤 5 中的图像 2,3 Hover-1 Titan Charge Port Replacement: 步骤 5 中的图像 3,3
    • Use an adjustable wrench to loosen the 14 mm nut and lift it off the charge port.
  6. Hover-1 Titan Charge Port Replacement: 步骤 6 中的图像 1,2 Hover-1 Titan Charge Port Replacement: 步骤 6 中的图像 2,2
    • Remove the old charge port by pulling the wires all the way through the panel.
    • Replace the old charge port with the new charge port.
结论
Jessica Ouyang
于10/08/18注册
619 声望
创作了4篇指南
团队
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 的会员
CPSU-WHITE-F18S15G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 657
