跳转到主内容
Hover-1 Titan Bottom Right Panel Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Hover-1 Titan Bottom Right Panel Replacement, Bottom Right Panel: 步骤 1 中的图像 1,2 Hover-1 Titan Bottom Right Panel Replacement, Bottom Right Panel: 步骤 1 中的图像 2,2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Bottom Right Panel Replacement: 步骤 2 中的图像 1,2 Hover-1 Titan Bottom Right Panel Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Bottom Right Panel Replacement: 步骤 3 中的图像 1,3 Hover-1 Titan Bottom Right Panel Replacement: 步骤 3 中的图像 2,3 Hover-1 Titan Bottom Right Panel Replacement: 步骤 3 中的图像 3,3
    • Grip the bottom right panel and lift to remove it.
结论
Dana Ebe
于10/08/18注册
238 声望
创作了2篇指南
团队
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 的会员
CPSU-WHITE-F18S15G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 45
