跳转到主内容
Hover-1 Titan Battery Replacement
你所需要的
  1. Hover-1 Titan Battery Replacement, Bottom Right Panel: 步骤 1 中的图像 1,2 Hover-1 Titan Battery Replacement, Bottom Right Panel: 步骤 1 中的图像 2,2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Battery Replacement: 步骤 2 中的图像 1,2 Hover-1 Titan Battery Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Battery Replacement: 步骤 3 中的图像 1,3 Hover-1 Titan Battery Replacement: 步骤 3 中的图像 2,3 Hover-1 Titan Battery Replacement: 步骤 3 中的图像 3,3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Battery Replacement, Battery: 步骤 4 中的图像 1,2 Hover-1 Titan Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Battery Replacement: 步骤 5 中的图像 1,2 Hover-1 Titan Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the bundle of wires from the clip on the top of the battery.
  6. Hover-1 Titan Battery Replacement: 步骤 6 中的图像 1,2 Hover-1 Titan Battery Replacement: 步骤 6 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four 14 mm screws that hold the battery on the device.
  7. Hover-1 Titan Battery Replacement: 步骤 7 中的图像 1,3 Hover-1 Titan Battery Replacement: 步骤 7 中的图像 2,3 Hover-1 Titan Battery Replacement: 步骤 7 中的图像 3,3
    • Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
结论
另外一个人完成了本指南。
Jessica Ouyang
于10/08/18注册
619 声望
创作了4篇指南
团队
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 的会员
CPSU-WHITE-F18S15G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 37
总计 1,945
