跳转到主内容
Hover-1 Superstar Speaker Replacement
你所需要的
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: 步骤 1 中的图像 1,3 Hover-1 Superstar Speaker Replacement, Bottom Case: 步骤 1 中的图像 2,3 Hover-1 Superstar Speaker Replacement, Bottom Case: 步骤 1 中的图像 3,3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Speaker Replacement: 步骤 2 中的图像 1,1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
  4. Hover-1 Superstar Speaker Replacement: 步骤 4 中的图像 1,1
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
  5. Hover-1 Superstar Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the speaker from its port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 260
