跳转到主内容
Hover-1 Rally Rear Wheel Replacement
你所需要的
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: 步骤 1 中的图像 1,1
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Rear Wheel Replacement: 步骤 2 中的图像 1,1
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Rear Wheel Replacement: 步骤 3 中的图像 1,2 Hover-1 Rally Rear Wheel Replacement: 步骤 3 中的图像 2,2
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Rear Wheel Replacement: 步骤 4 中的图像 1,1
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
结论
另外一个人完成了本指南。
Cami Lowrey
于02/07/20注册
435 声望
创作了3篇指南
团队
Cal Poly, Team S7-G2, Regan Winter 2020 Cal Poly, Team S7-G2, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G2
6 名成员
创作了7篇指南
一条评论
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 875
