跳转到主内容
Hover-1 Rally Acceleration Lever Replacement
你所需要的
  1. Hover-1 Rally Acceleration Lever Replacement, Acceleration Lever: 步骤 1 中的图像 1,1
    • Remove one 4 mm Phillips #1 screw located directly above the acceleration lever.
  2. Hover-1 Rally Acceleration Lever Replacement: 步骤 2 中的图像 1,2 Hover-1 Rally Acceleration Lever Replacement: 步骤 2 中的图像 2,2
    • Turn the right handle grip counterclockwise.
    • The right handle will disconnect from the handlebar, exposing the acceleration lever.
  3. Hover-1 Rally Acceleration Lever Replacement: 步骤 3 中的图像 1,1
    • Remove four 2 mm Phillips #00 screws located on the acceleration throttle.
  4. Hover-1 Rally Acceleration Lever Replacement: 步骤 4 中的图像 1,1
    • Pull the acceleration lever off of the handle.
    • The acceleration lever sits perpendicular to the handle.
结论
另外一个人完成了本指南。
Van Schneider
于02/10/20注册
112 声望
撰写一个指南
团队
Cal Poly, Team S7-G2, Regan Winter 2020 Cal Poly, Team S7-G2, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G2
6 名成员
创作了7篇指南
4条评论
Where did you find the lever?
Jaimi Erwin - 回复
See comment below. Swap out your power throttle with the brake lever. Or reach out to Hover-1 for spare parts.
Chris Serio -
Thank you Mr Fix It Man. I haven't used my scooter in months and never tried to find parts. Swapped my throttle out with my brake lever and we're good to go hehe
Chris Serio - 回复
The throttle lever on my daughter’s scooter broke off and I have been unable to get through to Hover for replacement parts (both online and tried to call). Do you know of any universal levers that would work? Or where I could locate a lever? Bought this for my daughter to get to college classes and this is her first week and it broke (out of 90 day warranty, of course.)
Sharon Kolson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 31
总计 2,043
