简介
If your Nomad does not charge, dies quickly, or does not drive predictably, your battery may be dying or damaged. Follow this guide to replace the battery in the Hover-1 Nomad.
你所需要的
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Cut the two zip ties around the bundle of wires with cutting pliers.
Disconnect the following wires connecting the circuit boards to the sensors and motors:
Disconnect the white connectors by pinching the tab and pulling up on the connectors.
Disconnect the black connectors by pulling the two sides apart.
Disconnect the green, yellow, and blue cables by pulling back the plastic shielding and pulling the ends apart.
另外一个人完成了本指南。
