跳转到主内容
Hover-1 Maverick Motor Wheel Replacement
你所需要的
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: 步骤 1 中的图像 1,3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: 步骤 1 中的图像 2,3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: 步骤 2 中的图像 1,2 Hover-1 Maverick Motor Wheel Replacement: 步骤 2 中的图像 2,2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: 步骤 3 中的图像 1,2 Hover-1 Maverick Motor Wheel Replacement: 步骤 3 中的图像 2,2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: 步骤 4 中的图像 1,2 Hover-1 Maverick Motor Wheel Replacement: 步骤 4 中的图像 2,2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: 步骤 5 中的图像 1,2 Hover-1 Maverick Motor Wheel Replacement, Motor: 步骤 5 中的图像 2,2
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: 步骤 6 中的图像 1,1
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
结论
Piper Feldman
于01/23/20注册
409 声望
创作了4篇指南
团队
Cal Poly, Team S2-G2, White Winter 2020 Cal Poly, Team S2-G2, White Winter 2020 的会员
CPSU-WHITE-W20S2G2
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 465
