跳转到主内容
Hover-1 Maverick Central Bearing Replacement
你所需要的
  1. Hover-1 Maverick Central Bearing Replacement, Central Bearing: 步骤 1 中的图像 1,3 Hover-1 Maverick Central Bearing Replacement, Central Bearing: 步骤 1 中的图像 2,3 Hover-1 Maverick Central Bearing Replacement, Central Bearing: 步骤 1 中的图像 3,3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell from the hoverboard. The central bearing is located in the center.
  2. Hover-1 Maverick Central Bearing Replacement: 步骤 2 中的图像 1,1
    • Unscrew the eight 16mm Phillips #1 screws holding the central bearing in place.
  3. Hover-1 Maverick Central Bearing Replacement: 步骤 3 中的图像 1,2 Hover-1 Maverick Central Bearing Replacement: 步骤 3 中的图像 2,2
    • Unplug the wires that run through the central bearing. There is a black and yellow one that attaches to the battery and a set of white ones that attach to the motherboard.
    • Run these wires out through the other end of the central bearing.
  4. Hover-1 Maverick Central Bearing Replacement: 步骤 4 中的图像 1,2 Hover-1 Maverick Central Bearing Replacement: 步骤 4 中的图像 2,2
    • One side of the bearing is easy to pop out with your hands.
    • The other side of the bearing has wiring for the LED light running under it, so it cannot be pulled out with your hands. To get leverage, carefully use the metal spudger to wedge out this other side.
  5. Hover-1 Maverick Central Bearing Replacement: 步骤 5 中的图像 1,1
    • Take the central bearing out of the board.
结论
Piper Feldman
于01/23/20注册
409 声望
创作了4篇指南
团队
Cal Poly, Team S2-G2, White Winter 2020 Cal Poly, Team S2-G2, White Winter 2020 的会员
CPSU-WHITE-W20S2G2
2 名成员
创作了4篇指南
一条评论
Where do I buy this central bearing of hover 1?
Sinan Sönmez - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 475
