跳转到主内容
Hover-1 Matrix Pad Replacement
你所需要的
  1. Hover-1 Matrix Pad Replacement, Pad: 步骤 1 中的图像 1,2 Hover-1 Matrix Pad Replacement, Pad: 步骤 1 中的图像 2,2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: 步骤 2 中的图像 1,1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: 步骤 3 中的图像 1,1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: 步骤 4 中的图像 1,2 Hover-1 Matrix Pad Replacement: 步骤 4 中的图像 2,2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: 步骤 5 中的图像 1,3 Hover-1 Matrix Pad Replacement: 步骤 5 中的图像 2,3 Hover-1 Matrix Pad Replacement: 步骤 5 中的图像 3,3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: 步骤 6 中的图像 1,1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
结论
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
另外一个人完成了本指南。
Jici Zhuang
于10/22/18注册
362 声望
创作了2篇指南
团队
UC Davis, Team S7-G2, Lore Fall 2018 UC Davis, Team S7-G2, Lore Fall 2018 的会员
UCD-LORE-F18S7G2
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 17
总计 570
