当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
To remove the connectors, pinch the plug and pull away from the circuit board.
Remove battery connector by pulling it apart.
Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
Disconnect the colored wires by pulling them apart.
The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
To release the cable connector, squeeze the sides while pulling it away from the sensor board.
Place the hoverboard so the four 36mm Allen bolts are pointing up.
Remove the four 36mm Allen bolts on each side using a 5mm Allen Wrench.
The four Allen bolts have lock washers.
Lift motor assembly away from hoverboard.
There is a flat section on the motor shaft that needs to point up, towards metal plate.
The motor assembly should be flush with side of hoverboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
