跳转到主内容
Hover-1 Liberty Gyroscope Sensor Boards Replacement
你所需要的
  1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 2 中的图像 1,2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 2 中的图像 2,2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 3 中的图像 1,3 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 3 中的图像 2,3 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 3 中的图像 3,3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Gyroscope Sensor Boards: 步骤 4 中的图像 1,1
    • Place the hoverboard so the sensor boards face you.
  5. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 5 中的图像 1,2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 5 中的图像 2,2
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
  6. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 6 中的图像 1,2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 6 中的图像 2,2
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
  7. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 7 中的图像 1,2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 7 中的图像 2,2
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
  8. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 8 中的图像 1,2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 步骤 8 中的图像 2,2
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
结论
6等其他人完成本指南。
Eduardo Miranda
于10/08/18注册
313 声望
创作了2篇指南
团队
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 的会员
CPSU-WHITE-F18S13G2
3 名成员
创作了4篇指南
8条评论
Where can you purchase the replacement board for the Hover-1 liberty?
Clifton Hale - 回复
Where do you get replacement board?
Tim Sole - 回复
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Regina - 回复
Make this site useful by telling us where we can buy a new circuit board.
tim stoinski - 回复
Where do you get circuit board from.
markrichardowen - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 88
总计 7,746
