跳转到主内容
加入维修社区 - 创建账户
Hover-1 Liberty Bottom Cover Replacement
你所需要的
    1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 2,2
      • Flip the hoverboard over so the labels are facing upwards.
      • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
      询问修复机器人
      添加评论
    2. Hover-1 Liberty Bottom Cover Replacement: 步骤 2 中的图像 1,2 Hover-1 Liberty Bottom Cover Replacement: 步骤 2 中的图像 2,2
      • Remove the bottom cover by lifting it away from the hoverboard.
      • The cover on the side without the battery has two wires connecting the power button and charging port.
      询问修复机器人
      添加评论
    3. Hover-1 Liberty Bottom Cover Replacement: 步骤 3 中的图像 1,3 Hover-1 Liberty Bottom Cover Replacement: 步骤 3 中的图像 2,3 Hover-1 Liberty Bottom Cover Replacement: 步骤 3 中的图像 3,3
      • Remove one connector from the non-battery side circuit board.
      • Remove the next connector from the non-battery side circuit board.
      • To remove the connectors, pinch the plug and pull away from the circuit board.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Patrick Bacon
于10/08/18注册
438 声望
创作了2篇指南
团队
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 的会员
CPSU-WHITE-F18S13G2
3 名成员
创作了4篇指南
2指南评论
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - 回复 分享
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 47
总计 3,710
