本指南有最近更改,您可查看未经巡查的最新版本。
简介
If your Hover-1 Liberty is not holding a charge and there is no problem with the charging cord, then the battery needs to be replaced. In this guide, the side of the hoverboard with the words Hover-1 printed on it will be referred to as the right side.
你所需要的
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Disconnect the large red and black wire from the battery by pulling apart the connector.
另外一个人完成了本指南。
