跳转到主内容
加入维修社区 - 创建账户
Hover-1 Liberty Battery Replacement
你所需要的
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Hover-1 Liberty Battery Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    询问修复机器人
    添加评论
  2. Hover-1 Liberty Battery Replacement: 步骤 2 中的图像 1,2 Hover-1 Liberty Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    询问修复机器人
    添加评论
  3. Hover-1 Liberty Battery Replacement: 步骤 3 中的图像 1,3 Hover-1 Liberty Battery Replacement: 步骤 3 中的图像 2,3 Hover-1 Liberty Battery Replacement: 步骤 3 中的图像 3,3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    添加评论
  4. Hover-1 Liberty Battery Replacement, Battery: 步骤 4 中的图像 1,2 Hover-1 Liberty Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
    询问修复机器人
    添加评论
  5. Hover-1 Liberty Battery Replacement: 步骤 5 中的图像 1,2 Hover-1 Liberty Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
    询问修复机器人
    添加评论
  6. Hover-1 Liberty Battery Replacement: 步骤 6 中的图像 1,2 Hover-1 Liberty Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
    询问修复机器人
    添加评论
  7. Hover-1 Liberty Battery Replacement: 步骤 7 中的图像 1,3 Hover-1 Liberty Battery Replacement: 步骤 7 中的图像 2,3 Hover-1 Liberty Battery Replacement: 步骤 7 中的图像 3,3
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Patrick Bacon
于10/08/18注册
438 声望
创作了2篇指南
团队
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 的会员
CPSU-WHITE-F18S13G2
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 55
总计 3,275
