跳转到主内容
Hover-1 Horizon Left Balancing Sensor Replacement
你所需要的
  1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: 步骤 1 中的图像 1,2 Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: 步骤 1 中的图像 2,2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 2 中的图像 1,2 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 2 中的图像 2,2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 3 中的图像 1,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 3 中的图像 2,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 3 中的图像 3,3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: 步骤 4 中的图像 1,3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: 步骤 4 中的图像 2,3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: 步骤 4 中的图像 3,3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 5 中的图像 1,2 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 5 中的图像 2,2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 6 中的图像 1,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 6 中的图像 2,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 6 中的图像 3,3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 7 中的图像 1,2 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 7 中的图像 2,2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 8 中的图像 1,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 8 中的图像 2,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 8 中的图像 3,3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 9 中的图像 1,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 9 中的图像 2,3 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 9 中的图像 3,3
    • Unclip the black connector by squeezing both sides and pulling them apart.
  10. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: 步骤 10 中的图像 1,3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: 步骤 10 中的图像 2,3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: 步骤 10 中的图像 3,3
    • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
    • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
  11. Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 11 中的图像 1,2 Hover-1 Horizon Left Balancing Sensor Replacement: 步骤 11 中的图像 2,2
    • Remove the sensor tab by carefully lifting it away from the hoverboard.
结论
Jesus
于10/08/18注册
85 声望
撰写一个指南
团队
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018 的会员
CPSU-WHITE-F18S13G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 859
