跳转到主内容
Hover-1 H1 Power Button Replacement
你所需要的
  1. Hover-1 H1 Power Button  Replacement, Bottom Shell: 步骤 1 中的图像 1,1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Power Button  Replacement: 步骤 2 中的图像 1,1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Power Button  Replacement: 步骤 3 中的图像 1,2 Hover-1 H1 Power Button  Replacement: 步骤 3 中的图像 2,2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Power Button  Replacement: 步骤 4 中的图像 1,1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Power Button  Replacement, Power Button: 步骤 5 中的图像 1,1
    • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
    • Pull the cable through the center section of the hoverboard.
    • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
  6. Hover-1 H1 Power Button  Replacement: 步骤 6 中的图像 1,2 Hover-1 H1 Power Button  Replacement: 步骤 6 中的图像 2,2
    • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
  7. Hover-1 H1 Power Button  Replacement: 步骤 7 中的图像 1,1
    • Pull the power button through the hole in the shell.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 的会员
CPSU-WHITE-F18S17G6
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 58
总计 3,014
