跳转到主内容
Hover-1 H1 LED Headlight Replacement
你所需要的
  1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: 步骤 1 中的图像 1,1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 LED Headlight Replacement: 步骤 2 中的图像 1,1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 LED Headlight Replacement: 步骤 3 中的图像 1,2 Hover-1 H1 LED Headlight Replacement: 步骤 3 中的图像 2,2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 LED Headlight Replacement: 步骤 4 中的图像 1,1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 LED Headlight Replacement, LED Headlights: 步骤 5 中的图像 1,1
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
  6. Hover-1 H1 LED Headlight Replacement: 步骤 6 中的图像 1,1
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
  7. Hover-1 H1 LED Headlight Replacement: 步骤 7 中的图像 1,1
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
结论
另外一个人完成了本指南。
Sara Passantino
于10/08/18注册
326 声望
创作了2篇指南
团队
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 的会员
CPSU-WHITE-F18S17G6
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,289
