跳转到主内容
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
你所需要的
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: 步骤 1 中的图像 1,1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 2 中的图像 1,1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 3 中的图像 1,2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 3 中的图像 2,2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 4 中的图像 1,1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 步骤 5 中的图像 1,2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 步骤 5 中的图像 2,2
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 6 中的图像 1,2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 6 中的图像 2,2
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 7 中的图像 1,2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 7 中的图像 2,2
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 8 中的图像 1,1
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 9 中的图像 1,3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 9 中的图像 2,3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 9 中的图像 3,3
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 10 中的图像 1,1
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 11 中的图像 1,2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 11 中的图像 2,2
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 12 中的图像 1,2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 12 中的图像 2,2
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 步骤 13 中的图像 1,1
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
结论
5等其他人完成本指南。
Aaron Teh
于10/08/18注册
442 声望
创作了2篇指南
团队
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 的会员
CPSU-WHITE-F18S17G6
4 名成员
创作了7篇指南
一条评论
where can I get the replacement parts?
Rob Sayles - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 114
总计 4,847
