简介
Replacing the charging port of your Hover-1 H1 hoverboard will help to solve charging problems.
你所需要的
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
即将完成!
结论
