跳转到主内容
Hover-1 H1 Charging Port Replacement
你所需要的
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: 步骤 1 中的图像 1,1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: 步骤 3 中的图像 1,2 Hover-1 H1 Charging Port Replacement: 步骤 3 中的图像 2,2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: 步骤 4 中的图像 1,1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,2 Hover-1 H1 Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: 步骤 7 中的图像 1,2 Hover-1 H1 Charging Port Replacement: 步骤 7 中的图像 2,2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: 步骤 8 中的图像 1,2 Hover-1 H1 Charging Port Replacement: 步骤 8 中的图像 2,2
    • Pull the charging port to the left through the shell.
结论
Madeline David
于10/08/18注册
280 声望
创作了2篇指南
团队
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 的会员
CPSU-WHITE-F18S17G6
4 名成员
创作了7篇指南
一条评论
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 59
总计 3,897
