跳转到主内容
Hover-1 Folding E-Scooter Rear Wheel Replacement
你所需要的
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: 步骤 1 中的图像 1,2 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: 步骤 1 中的图像 2,2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 2 中的图像 1,3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 2 中的图像 2,3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 2 中的图像 3,3
    • Slide off the plastic side panel.
    What is the Pat number of this plastic side panel?
    bobdub - 回复
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 3 中的图像 1,1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 4 中的图像 1,1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 5 中的图像 1,3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 5 中的图像 2,3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 5 中的图像 3,3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: 步骤 6 中的图像 1,1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
结论
Luke Imai
于10/08/18注册
133 声望
撰写一个指南
团队
Cal Poly, Team S15-G5, White Fall 2018 Cal Poly, Team S15-G5, White Fall 2018 的会员
CPSU-WHITE-F18S15G5
4 名成员
创作了5篇指南
2条评论
Where can you get replacement rubber for the front and rear wheels?
jackricotta - 回复
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 43
总计 5,169
