简介
Is your deck on your Hover-1 Folding eScooter damaged? If so here is a guide to help you replace it with a new one.
你所需要的
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
Hold the two 10mm nuts in place with a 10mm wrench.
Remove the two 33mm bolts connected to the 10 mm nuts by turning a hex 4.0 screwdriver counterclockwise.
To reassemble your device, follow these instructions in reverse order and use the new deck instead.
另外一个人完成了本指南。
2条评论
The latch does not operate properly and is missing a part on the right side so it cannot retract the steel bar that locks the position. What part do I need and can you pls send it? It’s a brand new unit.
step 7 is where mine is broken .. it was kicked hard and right after the 2 screws but before the curb has been snapped what do i do
