跳转到主内容
Hover-1 Folding E-Scooter Brake Switch Replacement
你所需要的
  1. Hover-1 Folding E-Scooter Brake Switch Replacement, Brake Switch: 步骤 1 中的图像 1,1
    • Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
    • You will need to twist the handle clockwise reattach it to the scooter's main body.
  2. Hover-1 Folding E-Scooter Brake Switch Replacement: 步骤 2 中的图像 1,2 Hover-1 Folding E-Scooter Brake Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
    • These screws are small and easy to lose.
    • When inserting for reassembly the screws twist clockwise to secure.
  3. Hover-1 Folding E-Scooter Brake Switch Replacement: 步骤 3 中的图像 1,3 Hover-1 Folding E-Scooter Brake Switch Replacement: 步骤 3 中的图像 2,3 Hover-1 Folding E-Scooter Brake Switch Replacement: 步骤 3 中的图像 3,3
    • Remove the red brake switch by sliding it off the main body.
    • When putting the brake switch back make sure to align the tab with the throttle switch.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S15-G5, White Fall 2018 Cal Poly, Team S15-G5, White Fall 2018 的会员
CPSU-WHITE-F18S15G5
4 名成员
创作了5篇指南
6条评论
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Angela Renteria - 回复
Hi, I’m looking for a Hover-1 Eagle left handle?  Do you where can I find it? Thanks
Keila Talarico - 回复
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - 回复
Looking new break switch.where we will get?. please reply.
Vitesh - 回复
Looking for a throttle switch. Know where I can find one?
Mara - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 4,618
