跳转到主内容
简介
This guide will walk you through how to replace a faulty or non-functional throttle or brake lever on a Hover-1 Eagle scooter. You should replace your throttle or brake lever if your lever fails to accelerate or stop the scooter or appears damaged. To determine if you need to replace your throttle or brake lever, refer to our Troubleshooting Guide.
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 步骤 1 中的图像 1,3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 步骤 1 中的图像 2,3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 步骤 1 中的图像 3,3
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 2 中的图像 1,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 2 中的图像 2,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 2 中的图像 3,3
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 3 中的图像 1,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 3 中的图像 2,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 3 中的图像 3,3
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 4 中的图像 1,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 4 中的图像 2,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 4 中的图像 3,3
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 5 中的图像 1,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 5 中的图像 2,3 Hover-1 Eagle Throttle/Brake Lever Replacement: 步骤 5 中的图像 3,3
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
终点
3等其他人完成本指南。
Andrew Gaskell
于2020年01月23日注册
876 声望分
创作了5篇指南
团队
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 的会员
CPSU-WHITE-W20S1G2
4 名成员
创作了5篇指南
18条评论
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - 回复
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - 回复
Necesito acelerador y no lo encuentro.
Josue Villanueva - 回复
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - 回复
添加评论
浏览统计数据:
过去的24小时: 15
过去的7天: 120
过去的30天: 538
总计 11,447
