跳转到主内容
Hover-1 Eagle LED Headlight Replacement
你所需要的
  1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: 步骤 1 中的图像 1,3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: 步骤 1 中的图像 2,3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: 步骤 1 中的图像 3,3
    • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
  2. Hover-1 Eagle LED Headlight Replacement: 步骤 2 中的图像 1,3 Hover-1 Eagle LED Headlight Replacement: 步骤 2 中的图像 2,3 Hover-1 Eagle LED Headlight Replacement: 步骤 2 中的图像 3,3
    • Carefully remove the top of the housing containing the display screen.
    • Remove the top of the housing slowly to avoid damaging the wires.
  3. Hover-1 Eagle LED Headlight Replacement: 步骤 3 中的图像 1,2 Hover-1 Eagle LED Headlight Replacement: 步骤 3 中的图像 2,2
    • Slide the LED light cover upwards out of the display housing
    • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
    • The LED circuit board should slide out with the LED light cover.
    • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
  4. Hover-1 Eagle LED Headlight Replacement: 步骤 4 中的图像 1,3 Hover-1 Eagle LED Headlight Replacement: 步骤 4 中的图像 2,3 Hover-1 Eagle LED Headlight Replacement: 步骤 4 中的图像 3,3
    • Using a soldering iron, desolder the black and red wires from the LED circuit board.
    • To reassemble, solder the same black and red wires onto the new LED circuit board.
结论
4等其他人完成本指南。
Andrew Gaskell
于01/23/20注册
1,008 声望
创作了5篇指南
团队
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 的会员
CPSU-WHITE-W20S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,025
