简介
If your Hover-1 Coast board’s power button won't press you likely have an issue with the button spring. This spring allows the button to be compressed, sending a signal to the battery to turn on and power the board.
This will be a moderately difficult task to complete as you will use tools that not everyone probably has but are common for most electronics repairs.
Provided to you, is a list of detailed instructions on how to properly, and safely replace the spring. For parts please go ++here++ to look at how to purchase new parts. For any inquiries, please take a look at the operator’s manual link ++here++.
你所需要的
To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
Using a pick tool, puncture the grip tape and expose the screws.
Loosen all four 1" screws using a Phillips #1 screwdriver.
Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
