跳转到主内容
Hover-1 Coast Board Battery Replacement
你所需要的
  1. Hover-1 Coast Board Battery Replacement, Board Battery: 步骤 1 中的图像 1,3 Hover-1 Coast Board Battery Replacement, Board Battery: 步骤 1 中的图像 2,3 Hover-1 Coast Board Battery Replacement, Board Battery: 步骤 1 中的图像 3,3
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Hover-1 Coast Board Battery Replacement: 步骤 2 中的图像 1,3 Hover-1 Coast Board Battery Replacement: 步骤 2 中的图像 2,3 Hover-1 Coast Board Battery Replacement: 步骤 2 中的图像 3,3
    • Now pull the black protective cover off the board.
    • Locate the battery.
  3. Hover-1 Coast Board Battery Replacement: 步骤 3 中的图像 1,3 Hover-1 Coast Board Battery Replacement: 步骤 3 中的图像 2,3 Hover-1 Coast Board Battery Replacement: 步骤 3 中的图像 3,3
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
  4. Hover-1 Coast Board Battery Replacement: 步骤 4 中的图像 1,3 Hover-1 Coast Board Battery Replacement: 步骤 4 中的图像 2,3 Hover-1 Coast Board Battery Replacement: 步骤 4 中的图像 3,3
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
结论
另外一个人完成了本指南。
一条评论
Where can you order a replacement battery?
Phil - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 609
