跳转到主内容
Hover-1 Chrome Outer Shell Replacement
你所需要的
  1. Hover-1 Chrome Outer Shell Replacement, Hover-1 Chrome Disassembly: 步骤 1 中的图像 1,1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Outer Shell Replacement: 步骤 2 中的图像 1,1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Outer Shell Replacement: 步骤 3 中的图像 1,2 Hover-1 Chrome Outer Shell Replacement: 步骤 3 中的图像 2,2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Outer Shell Replacement, Outer Shell: 步骤 4 中的图像 1,1
    • Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
    • The other six screws are on the side without the battery.
  5. Hover-1 Chrome Outer Shell Replacement: 步骤 5 中的图像 1,3 Hover-1 Chrome Outer Shell Replacement: 步骤 5 中的图像 2,3 Hover-1 Chrome Outer Shell Replacement: 步骤 5 中的图像 3,3
    • Free the cables held atop the bracket holding the battery in place.
    • Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
    • Pull the battery bracket free.
  6. Hover-1 Chrome Outer Shell Replacement: 步骤 6 中的图像 1,1
    • Unplug the cords for the top LEDs.
    • The other side of the board is structurally symmetrical. However instead of going under the battery bracket, these cords go through a zip tie. These cables must be removed from the zip tie in order to continue.
  7. Hover-1 Chrome Outer Shell Replacement: 步骤 7 中的图像 1,1
    • Turn the board over and pull the top panel off.
终点
Dylan Prins
于10/08/18注册
212 声望
撰写一个指南
团队
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 的会员
CPSU-WHITE-F18S4G1
4 名成员
创作了6篇指南
一条评论
Where can i get a replacement shell?
born4roblox - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 297
