跳转到主内容
Hover-1 Chrome Left Gyroscope Sensor Board Replacement
你所需要的
  1. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Hover-1 Chrome Disassembly: 步骤 1 中的图像 1,1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 2 中的图像 1,1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 3 中的图像 1,2 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 3 中的图像 2,2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 步骤 4 中的图像 1,3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 步骤 4 中的图像 2,3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 步骤 4 中的图像 3,3
    • Disconnect the speaker cable.
    • Disconnect the cable that travels to the other sensor board.
  5. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 5 中的图像 1,3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 5 中的图像 2,3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 5 中的图像 3,3
    • Disconnect the smaller connector midway on the cable.
    • Disconnect the larger connector midway on the cable.
  6. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 6 中的图像 1,1
    • Remove the four 12mm Phillips #2 screws securing the sensor board.
  7. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 7 中的图像 1,2 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 步骤 7 中的图像 2,2
    • Locate the five solder locations on the underside of the gyroscope sensor board.
    • Plug in soldering iron and wait for the tip tip to reach its target temperature.
    • Rest the tip of the iron on the solder and wait for the solder to melt. The wire will drop out of the sensor board.
    • Be aware of where the tip of the soldering iron is at ALL times. Put on safety glasses before picking up the soldering iron. Turn on a fan and face it towards the device to vent harmful fumes away from the solderers face.
结论
Nick McGuire
于10/08/18注册
551 声望
创作了4篇指南
团队
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 的会员
CPSU-WHITE-F18S4G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 1,086
