跳转到主内容
Hover-1 Chrome Bluetooth Speaker Replacement
你所需要的
  1. Hover-1 Chrome Bluetooth Speaker Replacement, Bluetooth Speaker: 步骤 1 中的图像 1,1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Bluetooth Speaker Replacement: 步骤 2 中的图像 1,1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Bluetooth Speaker Replacement: 步骤 3 中的图像 1,1
    • Lift the shell with the speaker grille so the speaker can be accessed.
    • Remove the three 14 mm Phillips #2 screws holding the speaker to the bottom left shell.
  4. Hover-1 Chrome Bluetooth Speaker Replacement: 步骤 4 中的图像 1,3 Hover-1 Chrome Bluetooth Speaker Replacement: 步骤 4 中的图像 2,3 Hover-1 Chrome Bluetooth Speaker Replacement: 步骤 4 中的图像 3,3
    • Pull off the bracket holding the speaker in place.
    • Place the speaker to the side so that the tab on the cable connector to the sound card can be accessed.
  5. Hover-1 Chrome Bluetooth Speaker Replacement: 步骤 5 中的图像 1,2 Hover-1 Chrome Bluetooth Speaker Replacement: 步骤 5 中的图像 2,2
    • Disconnect the cable attaching the speaker to the sound card.
结论
2等其他人完成本指南。
Nick McGuire
于10/08/18注册
551 声望
创作了4篇指南
团队
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 的会员
CPSU-WHITE-F18S4G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 671
