跳转到主内容
简介
Learn how to replace the battery with this guide. Any power related problems may need a battery replacement. For this guide, you will need a Phillips #2 screwdriver and a metal spudger.
配件
没有特定配件。
  1. Hover-1 Chrome Battery Replacement, Hover-1 Chrome Disassembly: 步骤 1 中的图像 1,1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Battery Replacement: 步骤 2 中的图像 1,1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Battery Replacement: 步骤 3 中的图像 1,2 Hover-1 Chrome Battery Replacement: 步骤 3 中的图像 2,2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
    • Use the metal spudger only as a last resort if the adhesive is too strong for either your hands or other plastic prying tools.
    • Use the spudger to pry the battery loose from the adhesive.
  5. Hover-1 Chrome Battery Replacement: 步骤 5 中的图像 1,2 Hover-1 Chrome Battery Replacement: 步骤 5 中的图像 2,2
    • Pull and wiggle the battery completely off of the adhesive using your hands.
    • Remove the battery from the body.
结论
另外一个人完成了本指南。
Nick McGuire
于2018年10月08日注册
551 声望分
创作了4篇指南
团队
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 的会员
CPSU-WHITE-F18S4G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 3
过去的30天: 7
总计 400
