跳转到主内容
加入维修社区 - 创建账户
Hover-1 Charger Outer Shell Replacement
你所需要的
  1. Hover-1 Charger Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 1,2 Hover-1 Charger Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 2,2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Outer Shell Replacement: 步骤 2 中的图像 1,1
    • Pull the right cover away from the hoverboard.
  3. Hover-1 Charger Outer Shell Replacement: 步骤 3 中的图像 1,2 Hover-1 Charger Outer Shell Replacement: 步骤 3 中的图像 2,2
    • Unscrew four 12 mm screws that hold the right foot pad with a Philips #2 screwdriver.
    • Unscrew the four 18 mm screws with a Philips #2 screwdriver.
    • Use a long, thin screwdriver to access the two 12 mm screws nearest to the wheel.
  4. Hover-1 Charger Outer Shell Replacement: 步骤 4 中的图像 1,2 Hover-1 Charger Outer Shell Replacement: 步骤 4 中的图像 2,2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  5. Hover-1 Charger Outer Shell Replacement: 步骤 5 中的图像 1,3 Hover-1 Charger Outer Shell Replacement: 步骤 5 中的图像 2,3 Hover-1 Charger Outer Shell Replacement: 步骤 5 中的图像 3,3
    • Unplug the black, yellow, green and red four pin connector from the circuit board.
    • Unplug the red and black two pin connector from the circuit board.
  6. Hover-1 Charger Outer Shell Replacement: 步骤 6 中的图像 1,2 Hover-1 Charger Outer Shell Replacement: 步骤 6 中的图像 2,2
    • Thread the black, yellow, green, and red four pin connector through the opening to the left of the battery.
    • Remove the right foot pad from the hoverboard.
  7. Hover-1 Charger Outer Shell Replacement: 步骤 7 中的图像 1,1
    • Pull the left cover away from the hoverboard.
  8. Hover-1 Charger Outer Shell Replacement: 步骤 8 中的图像 1,2 Hover-1 Charger Outer Shell Replacement: 步骤 8 中的图像 2,2
    • Unplug the red and white five pin connector from the circuit board.
    • Thread this connector through the middle cylinder.
    • Remove the right cover from the hoverboard.
  9. Hover-1 Charger Outer Shell Replacement: 步骤 9 中的图像 1,2 Hover-1 Charger Outer Shell Replacement: 步骤 9 中的图像 2,2
    • Unplug the red and white four pin connector from the speaker circuit board.
    • Unplug the blue and white three pin connector.
    • Unplug the blue and white two pin connector. This is photographed as an example.
  10. Hover-1 Charger Outer Shell Replacement: 步骤 10 中的图像 1,1
    • Remove the left cover from the hoverboard.
  11. Hover-1 Charger Outer Shell Replacement: 步骤 11 中的图像 1,2 Hover-1 Charger Outer Shell Replacement: 步骤 11 中的图像 2,2
    • Disconnect the two pronged black and yellow cable.
  12. Hover-1 Charger Outer Shell Replacement: 步骤 12 中的图像 1,3 Hover-1 Charger Outer Shell Replacement: 步骤 12 中的图像 2,3 Hover-1 Charger Outer Shell Replacement: 步骤 12 中的图像 3,3
    • Remove three black and red two pin connectors from the left circuit board.
    • Remove the red, yellow, and black three pin connector.
    • Remove zip tie if present.
  13. Hover-1 Charger Outer Shell Replacement: 步骤 13 中的图像 1,1
    • Unscrew four 12 mm screws from the sides holding the left foot pad with a Phillips #2 screwdriver.
    • Unscrew four 18 mm screws with a Phillips #2 screwdriver.
  14. Hover-1 Charger Outer Shell Replacement: 步骤 14 中的图像 1,1
    • Remove the left foot pad from the hoverboard.
结论
另外一个人完成了本指南。
Mark Rapiz
于10/10/19注册
253 声望
撰写一个指南
团队
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G1
4 名成员
创作了6篇指南
1指南评论
Where do I buy the shell their website doesnt have it
firestineanthony - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 701
