跳转到主内容
Hover 1 Eclipse Motherboard Replacement
你所需要的
  1. Hover 1 Eclipse Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Hover 1 Eclipse Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Hover 1 Eclipse Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
    • Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Motherboard Replacement: 步骤 2 中的图像 1,3 Hover 1 Eclipse Motherboard Replacement: 步骤 2 中的图像 2,3 Hover 1 Eclipse Motherboard Replacement: 步骤 2 中的图像 3,3
    • On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom left shell piece.
  3. Hover 1 Eclipse Motherboard Replacement: 步骤 3 中的图像 1,1
    • Unplug the yellow tipped plug, Xt60, attached to the red and black cord on the non-battery side.
  4. Hover 1 Eclipse Motherboard Replacement: 步骤 4 中的图像 1,3 Hover 1 Eclipse Motherboard Replacement: 步骤 4 中的图像 2,3 Hover 1 Eclipse Motherboard Replacement: 步骤 4 中的图像 3,3
    • Unplug the yellow tipped plug attached to the red and black cords.
    • Unplug the black headers attached to the white, skinny cord.
    • Unplug the green, blue and yellow plugs by pressing down the silver, under the clear plastic and pulling it apart.
  5. Hover 1 Eclipse Motherboard Replacement: 步骤 5 中的图像 1,2 Hover 1 Eclipse Motherboard Replacement: 步骤 5 中的图像 2,2
    • Unplug the white header attached to the pink and white cord.
    • Using a Phillips #1 screwdriver, remove the four screws from each corner of the motherboard.
    • Repeat steps 3 and 4 on the other side.
  6. Hover 1 Eclipse Motherboard Replacement: 步骤 6 中的图像 1,1
    • You have now removed the motherboards from both sides.
结论
Mina Dedijer
于10/10/19注册
548 声望
创作了4篇指南
团队
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G4
4 名成员
创作了5篇指南
7指南评论
Can you please drop links to purchase the 2 motherboards?
Frank - 回复
Hi
wondering if you know the part numbers and where to obtain the boards?
Dave - 回复
We’re do you get the boards at I really need them
Ashton Mcalvain - 回复
We’re do get the boards?
Hector Ortiz - 回复
Any idea where to buy parts and the price?
william bowen - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 2,348
