跳转到主内容
Hover 1 Eclipse Bluetooth Speaker Replacement
你所需要的
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: 步骤 1 中的图像 1,3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: 步骤 1 中的图像 2,3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: 步骤 1 中的图像 3,3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: 步骤 2 中的图像 1,3 Hover 1 Eclipse Bluetooth Speaker Replacement: 步骤 2 中的图像 2,3 Hover 1 Eclipse Bluetooth Speaker Replacement: 步骤 2 中的图像 3,3
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: 步骤 3 中的图像 1,3 Hover 1 Eclipse Bluetooth Speaker Replacement: 步骤 3 中的图像 2,3 Hover 1 Eclipse Bluetooth Speaker Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
结论
Mina Dedijer
于10/10/19注册
548 声望
创作了4篇指南
团队
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 486
