跳转到主内容
Hover 1 Eclipse Battery Replacement
  1. Hover 1 Eclipse Battery Replacement, Battery: 步骤 1 中的图像 1,3 Hover 1 Eclipse Battery Replacement, Battery: 步骤 1 中的图像 2,3 Hover 1 Eclipse Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Battery Replacement: 步骤 2 中的图像 1,2 Hover 1 Eclipse Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the black and red wires connected by an yellow header, Xt60.
    • This wire connects the battery to the motherboard.
    • Carefully tug on the two sides of the yellow header to disconnect them.
  3. Hover 1 Eclipse Battery Replacement: 步骤 3 中的图像 1,3 Hover 1 Eclipse Battery Replacement: 步骤 3 中的图像 2,3 Hover 1 Eclipse Battery Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that secure the black plastic keeping the battery in place.
    • Carefully remove the black plastic from the hoverboard.
    • Be mindful of the wires surrounding the battery.
  4. Hover 1 Eclipse Battery Replacement: 步骤 4 中的图像 1,2 Hover 1 Eclipse Battery Replacement: 步骤 4 中的图像 2,2
    • Be careful with the wires surrounding the battery when executing this step.
    • The battery is attached to the metal with an adhesive.
    • Firmly grasp the battery and tug on it until it is free from the metal.
结论
另外一个人完成了本指南。
Mina Dedijer
于10/10/19注册
548 声望
创作了4篇指南
团队
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 2,715
