跳转到主内容
Hott T725-8G Speaker Replacement
你所需要的
  1. Hott T725-8G Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Gently dislodge the speaker from the back panel so that it is only connected to the motherboard.
  2. Hott T725-8G Speaker Replacement: 步骤 2 中的图像 1,1
    • You can check the connection point between the speaker and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger.
    • Detach the wires using the plastic Spudger to replace the speaker.
结论
Emma Carroll
于10/20/16注册
193 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G2
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 85
