跳转到主内容
加入维修社区 - 创建账户
Hott T725-8G Battery Replacement
你所需要的
    1. Hott T725-8G Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
      询问修复机器人
      添加评论
    2. Hott T725-8G Battery Replacement: 步骤 2 中的图像 1,1
      • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
      • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
      询问修复机器人
      添加评论
    3. Hott T725-8G Battery Replacement: 步骤 3 中的图像 1,1
      • Carefully dislodge the speaker from the back panel.
      询问修复机器人
      添加评论
    1. Hott T725-8G Battery Replacement, Battery: 步骤 4 中的图像 1,1
      • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
      询问修复机器人
      添加评论
    2. Hott T725-8G Battery Replacement: 步骤 5 中的图像 1,1
      • Use your fingers to separate the ribbon wire from the battery and the back of the display.
      询问修复机器人
      添加评论
    3. Hott T725-8G Battery Replacement: 步骤 6 中的图像 1,1
      • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
      询问修复机器人
      添加评论
    4. Hott T725-8G Battery Replacement: 步骤 7 中的图像 1,1
      • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
      询问修复机器人
      添加评论
    5. Hott T725-8G Battery Replacement: 步骤 8 中的图像 1,1
      • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
      • Avoid using metal when working with batteries.
      • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
      询问修复机器人
      添加评论
    6. Hott T725-8G Battery Replacement: 步骤 9 中的图像 1,1
      • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G2
3 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 40
总计 711
