跳转到主内容
Hot Wheels AI Intelligent Race System Controller Transmitter Replacement
你所需要的
  1. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement, Controller Transmitter: 步骤 1 中的图像 1,1
    • Locate and remove the six screws on the back of the controller. Remove screws with a #J1 Philips head screwdriver.
  2. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 步骤 2 中的图像 1,1
    • With the controller facing down remove the top casing from the bottom. Do this by popping the casing lose which will expose the inside circuits.
  3. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 步骤 3 中的图像 1,1
    • With the circuits exposed locate the transmitter at the top of the controller. It is green hue in comparison to the rest of the blue circuits. Check the transmitter for damage or disconnected wires.
  4. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 步骤 4 中的图像 1,1
    • If transmitter has broken or has disconnected wires it may need replacement. Wires can easily break loose from the transmitter. The wires can easily be reinserted by sticking the wire back into its original slot.
  5. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 步骤 5 中的图像 1,1
    • If the transmitter is damaged, replace it by sliding the circuit down from its slot. Check for damage or burned out circuit.
    • Replace transmitter circuit with a new one by reinserting it into the original slot.
结论
1指南评论
Give the part numbers so we can source the circuits and change the devices if needed. Also can anyone extract the rim? I believe the rim being used is way low quality.
Luis Vitorio Cargnini - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 27
总计 1,098
