跳转到主内容
Hot Tools HPK12 Control Assembly Replacement
你所需要的
  1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 步骤 1 中的图像 1,3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 步骤 1 中的图像 2,3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 步骤 1 中的图像 3,3
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Control Assembly Replacement: 步骤 2 中的图像 1,1
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Control Assembly Replacement: 步骤 3 中的图像 1,2 Hot Tools HPK12 Control Assembly Replacement: 步骤 3 中的图像 2,2
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Control Assembly Replacement: 步骤 4 中的图像 1,1
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Control Assembly Replacement: 步骤 5 中的图像 1,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 5 中的图像 2,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 5 中的图像 3,3
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Control Assembly Replacement: 步骤 6 中的图像 1,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 6 中的图像 2,3 Hot Tools HPK12 Control Assembly Replacement: 步骤 6 中的图像 3,3
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
结论
另外一个人完成了本指南。
Aaron Whitlock
于10/24/16注册
249 声望
创作了2篇指南
团队
IUPUI, Team 3-4, Baechle Fall 2016 IUPUI, Team 3-4, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S3G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 36
总计 2,807
