跳转到主内容
Hori Real Arcade Pro N Push Button Replacement
你所需要的
  1. Hori Real Arcade Pro N Push Button Replacement, Push Button: 步骤 1 中的图像 1,2 Hori Real Arcade Pro N Push Button Replacement, Push Button: 步骤 1 中的图像 2,2
    • Flip your Fight Stick so the bottom is facing up.
    • Remove the sticker covering the screw in the bottom middle of the device.
    • Remove eight screws from the bottom of the device using a Phillips #0 screwdriver.
  2. Hori Real Arcade Pro N Push Button Replacement: 步骤 2 中的图像 1,2 Hori Real Arcade Pro N Push Button Replacement: 步骤 2 中的图像 2,2
    • Find the storage compartment that holds the USB wire.
    • Open the case by putting your hand in the compartment and pushing up.
    • Put your Fight Stick on its side to make the other steps easier.
  3. Hori Real Arcade Pro N Push Button Replacement: 步骤 3 中的图像 1,2 Hori Real Arcade Pro N Push Button Replacement: 步骤 3 中的图像 2,2
    • Use your fingers to pull the black grip to detach both wires connected to the pushbutton.
    • Pulling the wire instead of the black grip can cause the wires to not function.
  4. Hori Real Arcade Pro N Push Button Replacement: 步骤 4 中的图像 1,2 Hori Real Arcade Pro N Push Button Replacement: 步骤 4 中的图像 2,2
    • Twist the button you are planning to remove.
    • The tabs must be on its side as shown in the second picture so it is easier to grab in the next step.
  5. Hori Real Arcade Pro N Push Button Replacement: 步骤 5 中的图像 1,3 Hori Real Arcade Pro N Push Button Replacement: 步骤 5 中的图像 2,3 Hori Real Arcade Pro N Push Button Replacement: 步骤 5 中的图像 3,3
    • Squeeze the tabs in the button.
    • While squeezing, push the button inward, so it falls out.
结论
gabriel garcia
于01/24/22注册
121 声望
撰写一个指南
团队
CSU Los Angeles, Team 21-17, Briggs Spring 2022 CSU Los Angeles, Team 21-17, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S21G17
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 49
总计 1,715
