跳转到主内容
Hoover Windtunnel Air Steerable Upright Wheel Replacement
你所需要的
  1. Hoover Windtunnel Air Steerable Upright Wheel Replacement, Wheel: 步骤 1 中的图像 1,1
    • Lay the vacuum flat on the ground, then flip it over 180 degrees so that you can see the inside of the wheel.
  2. Hoover Windtunnel Air Steerable Upright Wheel Replacement: 步骤 2 中的图像 1,2 Hoover Windtunnel Air Steerable Upright Wheel Replacement: 步骤 2 中的图像 2,2
    • Locate the small metal pin and bolt holding the wheel in place.
  3. Hoover Windtunnel Air Steerable Upright Wheel Replacement: 步骤 3 中的图像 1,1
    • Take the needle nose pliers and stick them in the rectangular hole.
    • With the pliers, firmly grasp the metal pin that holds the bolt for the wheel in place.
    • Slide the pin off the bolt by pushing the pliers forward.
    • Carefully remove the pin from the rectangular hole and keep it in a safe place.
  4. Hoover Windtunnel Air Steerable Upright Wheel Replacement: 步骤 4 中的图像 1,1
    • Now, remove the wheel by pulling it away from the vacuum.
    • The bolt will come out with the wheel since the pin is gone.
终点
团队
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G2
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 30
总计 3,648
