跳转到主内容
Hoover Windtunnel Air Steerable Upright Suction Hose Replacement
你所需要的
  1. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement, Suction Hose: 步骤 1 中的图像 1,1
    • Turn the power off and unplug the power cord.
    • Set the cleaner in the upright position.
  2. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 步骤 2 中的图像 1,1
    • Dislodge hose from plastic clips for ease of removal.
  3. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 步骤 3 中的图像 1,1
    • Press firmly on the hose button and slide hose out.
  4. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 步骤 4 中的图像 1,3 Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 步骤 4 中的图像 2,3 Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 步骤 4 中的图像 3,3
    • Pull the hose out of the top of the vacuum.
    • The hose is connected to the vacuum handle.
    • The bottom of the hose should come out when the top of the hose is pulled away from the vacuum.
结论
steven hoover
于09/26/17注册
257 声望
创作了2篇指南
团队
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G2
5 名成员
创作了14篇指南
3条评论
what might my problem be? I will start vacuuming and the noise will change to an almost “air escaping” sound and it loses suction. It will make this sound when the filter is very dirty or when the bag is full.
Currently neither of these two things are applicable but it does it almost immediately after turning on. The sound change seems to be coming from the top of the main unit near the handle.
Mike - 回复
vacuum works hose for cleaning turn on off how to engage hose atachment turn on off
Richard Degrandcourt - 回复
how to turn on hose attachment?
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 45
总计 5,324
