跳转到主内容
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
你所需要的
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: 步骤 1 中的图像 1,2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: 步骤 1 中的图像 2,2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 2 中的图像 1,3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 2 中的图像 2,3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 2 中的图像 3,3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 3 中的图像 1,2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 3 中的图像 2,2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 步骤 4 中的图像 1,3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 步骤 4 中的图像 2,3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 步骤 4 中的图像 3,3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 5 中的图像 1,1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 6 中的图像 1,3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 6 中的图像 2,3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 步骤 6 中的图像 3,3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
结论
2等其他人完成本指南。
steven hoover
于09/26/17注册
257 声望
创作了2篇指南
团队
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G2
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 59
总计 3,881
