跳转到主内容
Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement
你所需要的
  1. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement, HEPA Filter: 步骤 1 中的图像 1,2 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement, HEPA Filter: 步骤 1 中的图像 2,2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 步骤 2 中的图像 1,3 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 步骤 2 中的图像 2,3 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 步骤 2 中的图像 3,3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 步骤 3 中的图像 1,2 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 步骤 3 中的图像 2,2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
终点
Spencer Nefores
于09/26/17注册
201 声望
创作了2篇指南
团队
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G2
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 45
总计 3,039
