简介
The primary air filter is in the vacuum's dust cap and prevents dust from being sucked out of the dust cup.
It's designed to be easily cleaned or replaced, so it's a quick process.
If your filter merely needs to be cleaned, you can follow this guide, but instead of replacing the filter you can rinse it under a faucet and reinstall it.
你所需要的
Press button on the top of the dust cup and pull back.
Remove dust cup from vacuum
另外一个人完成了本指南。
