跳转到主内容
Hoover WindTunnel 2 Rewind Primary Air Filter Replacement
你所需要的
  1. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement, Primary Air Filter: 步骤 1 中的图像 1,1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement: 步骤 2 中的图像 1,1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement: 步骤 3 中的图像 1,1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G4
5 名成员
创作了10篇指南
一条评论
Can I rinse it with warm water and soap? Or just warm water?
lacey sodapop - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 31
总计 2,428
