跳转到主内容
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
你所需要的
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: 步骤 1 中的图像 1,1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 步骤 2 中的图像 1,1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 步骤 3 中的图像 1,1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 步骤 4 中的图像 1,1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
结论
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6等其他人完成本指南。
Mickey McGuire
于01/22/18注册
253 声望
撰写一个指南
团队
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G4
5 名成员
创作了10篇指南
6条评论
Good job, helpful. Thanks!
Celeste Williams-Hughes - 回复
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - 回复
Same issue. Easy fix thanks!
mark camirand - 回复
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - 回复
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - 回复
I took the hose off and unclogged it but the vacuum still isn't turning back on, is there something else that may cause it to not work, or is it because the motor still needs to cool, and how long until it cools?
rpottle - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 41
过去 30 天: 136
总计 27,849
