跳转到主内容
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
你所需要的
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: 步骤 1 中的图像 1,1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 步骤 2 中的图像 1,1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 步骤 3 中的图像 1,1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 步骤 4 中的图像 1,1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
结论
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6等其他人完成本指南。
Mickey McGuire
于01/22/18注册
253 声望
撰写一个指南
团队
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G4
5 名成员
创作了10篇指南
6条评论
Good job, helpful. Thanks!
Celeste Williams-Hughes - 回复
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - 回复
Same issue. Easy fix thanks!
mark camirand - 回复
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - 回复
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 31
过去 30 天: 141
总计 27,892
