跳转到主内容
Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
你所需要的
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: 步骤 1 中的图像 1,1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 步骤 2 中的图像 1,1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 步骤 3 中的图像 1,1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: 步骤 4 中的图像 1,1
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 步骤 5 中的图像 1,2 Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 步骤 5 中的图像 2,2
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
结论
另外一个人完成了本指南。
Chino Cruz
于01/22/18注册
135 声望
撰写一个指南
团队
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G4
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 46
总计 4,599
